700hp on bravo I
Old 04-26-2011 | 04:52 PM
  #31
Im running 600hp in a 32 active thunder 7500 lb boat with bravo1s but i dont boat on any big lakes or ocean so boat never launches and i babby it on plane and ease the throttles and all is ok so far about 60hrs.
rssteiny is offline
Old 04-26-2011 | 07:40 PM
  #32
Ebay Ed's Avatar
what about a basicaly stock fresh hp 500 efi with a bravo 1 in a 272 baja am i on borrowed time ??
www.bajaboatowners.com
Ebay Ed is offline
Old 04-26-2011 | 08:25 PM
  #33
Originally Posted by SS930
If I were 'fixing' a bravo situation, this would be the order of fixes I'd throw at it (other than just avoiding "bravo butt" altogether in the first place)...
1) Arneson Conversion
2) B-Max or Imco SCX.
#1 will be costly, but cures the problem, plus you pick up some speed and gain a cool roaster-tail.
#2 will cost you some speed, but should hold up fairly well. Still not cheap though.
Pretty much anything else will be a costly band-aid, so save your pennies, you're going to be doing it again if you dont go with option 1 or 2.
Selling the boat and picking up something without BB (bravo butt) might be an even smarter move in the long run, but few people will see that as much of an option.
Has anyone done the Arneson conversion? I have a freshly whippled 525 with a Bravo XR that I imagine will be toast eventually. I will most likely be putting in the SCX/SC or the Arneson next winter. Any info would be great.
regor is offline
Old 04-26-2011 | 08:49 PM
  #34
Airpacker's Avatar
Pure torque will bust bravos. It literally rips the teeth off the gears. Baby it or not, if you run bigger water and have 700 lbft or more, your going to break gear sets. BTDT and after 5 or so you really get sick of paying for them.
I swapped to an SCX/SC combo and couldn't be happier. Smooth shifts, quiet and no more gear sets self destructing every 30 or so hours.
Airpacker is offline
Old 04-26-2011 | 09:09 PM
  #35
You are 100% absolutely correct. I have been there.
pacalim1965@yaho is offline
Old 04-26-2011 | 09:43 PM
  #36
How often are you servicing the SCX/SC? Everything I've read and been told, the XR should be every 20 hrs. At that rate, I'm looking at 4 to 5 services a season. I like to jump on it and I know I'm living on borrowed time. What's the purpose of the added HP and torque if you can't get on it.
regor is offline
Old 04-26-2011 | 11:24 PM
  #37
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
What kind of boat do you have?
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 04-27-2011 | 01:59 AM
  #38
hi Rik how ya doing? this is Jaime from Antioch. Has one been done on a 24Pantera? I remember Fin posting along time ago he was working on one with ASD. Im assuming it was a local boat, but my Pantera is the only one im aware of in the area. Thanks JAIME
JAIME is offline
Old 04-27-2011 | 07:04 AM
  #39
Airpacker's Avatar
I change the gear oil every secong engine oil change so 20 hrs max.
I went to the SCX because I want to be able to hammer the stick forward when I am cruising along. I do not want to have to baby the thing all the time. That takes the fun out of having the HP in the first place.
Old 04-27-2011 | 07:28 AM
  #40
SS930's Avatar
You should be relatively safe with the stock 500 efi. What typically fails on bravo based drives is the top gear. The 500 efi simply doesn't have enough torque to quickly damage the gear like a large SC engine will.
The only bravo based drives that should be considered reasonably robust are the ones that use a larger beefed up upper gear... such as the Imco SCX or the Bmax. The down side is these drives rob more power due to their more robust build.
You also still have to consider the options with the lower unit as well. The lower gears are also known to fail, but the vast majority of bravo failures are typically related to the upper gear. The SCX lower is more beefy, but it will rob even more speed. The Bmax historically used a bravo based lower gear, but I understand they are working on a more industrial lower and it should be on the market soon. Obviously we have no idea what kind of speed losses they'll see with this new lower. But again, the lower is not what usually fails, it's that pesky upper gear. Although, once the upper is addressed, I suppose the lower becomes the next weakest link...
SS930 is offline
