700hp on bravo I
Old 04-27-2011 | 08:57 AM
  #41
Originally Posted by Rik
What kind of boat do you have?
27 Daytona Rik
regor is offline
Old 04-27-2011 | 11:14 AM
  #42
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Originally Posted by regor
27 Daytona Rik
Doing one right now... The drive will fit no problem
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 04-27-2011 | 12:06 PM
  #43
I would be interested in the results Rik. What motor are they running?
regor is offline
Old 04-27-2011 | 12:50 PM
  #44
Rik's Avatar
Rik
? The hull is being laid up now... Will know more about the motor in a few weeks.
Rik is offline
Old 04-27-2011 | 07:05 PM
  #45
Originally Posted by Ebay Ed
what about a basicaly stock fresh hp 500 efi with a bravo 1 in a 272 baja am i on borrowed time ??
You are fine with that set up, i run royal purple in mmy drives every 20 hrs and having good luck that way.
rssteiny is offline
Old 04-27-2011 | 07:18 PM
  #46
Originally Posted by Uncle Dave
My experience is that with the best parts in a Bravo XR youll get about 50 hours in the ocean and around 100 on lakes taking it easy.
Gadgets is really good - so is acrticfriends.
Uncle Dave
GOOD LORD! IM JEALOUS. Freakin gorgeous colors!! The motor is unbelievable too. Well done!!
To the OP. If your Bravo is good. Sell it to someone with less power and save up for an ASD. Summers coming and those high top end numbers could give you some bragging rights. If im not correct isn't it possible to touch up into the three digit mph on his set up?
Im new to this sport but with high performance cars its the same way. If you go all motor high HP chances are your going to blow everything behind the flywheel. If you blow your drive 2 bad things will happen. You will not be able to sell your drive. Second you will feel like a jack a$$ when you have such a nice boat and will need a tow. You will probably save your self money and time in the long run. Im in the same boat as you, "Pun intended" but I think im going to wait and play is safe. A couple more paychecks and I will try to find a used ASD for my project.
Good luck. Show us some pics of the boat and motor!! 8)
VolaticusNavis is offline
Old 04-27-2011 | 09:34 PM
  #47
8)
Very nice compliment that you sir!
The guys at Laveycraft build a great boat, and Ilmor builds a sweet mill.
Uncle Dave
Uncle Dave is offline
Old 04-28-2011 | 11:14 PM
  #48
Uncle Dave
Sorry to get off topic OP
Uncle dave,
Where is that picture taken at? The one with the boat mored with the fish eye lens on. Looks like catalina.
Thanks,
Brandon
Old 04-28-2011 | 11:26 PM
  #49
Uncle dave,
Thanks,
Brandon
Correct- Avalon harbor.
My most common run is Marina Del rey to Avalon.
Ive run from Del rey to San Diego and back for long weekends as well this run is about 150 each way.
Back to the post I notice a big difference in ocean hours vs lake hours on my drive.
UD
Old 04-29-2011 | 01:11 AM
  #50
Sorry OP again.
Uncle dave im trying to PM you but your inbox is too full.
UD
