Bravo 1 vs. Bravo XR >
Old 05-05-2011 | 11:27 PM
Default Bravo 1 vs. Bravo XR
Can you and if so how do you tell the differance between a Bravo 1 lower and Bravo XR lower just by looking at them?
Osageparty is offline
Old 05-05-2011 | 11:29 PM
Look at the prop shaft. The xr will be larger.
soonenough is offline
Old 05-05-2011 | 11:36 PM
Plus the xr has a larger bullet.
GTOFFSHORE is offline
Old 05-06-2011 | 04:40 AM
Mr Gadgets's Avatar
Charter Member #601
Look for a blue bearing carrier and the 1.25" propshaft. The cases are the same size unless you look at a very early lower case.
Hope that helps.
Dick
Mr Gadgets is offline
