Driveshaft bellow replacement >
Old 05-12-2011 | 07:41 PM
Default Driveshaft bellow replacement
Is it nessasary to remove the bellhousing on a bravo outdrive to change the driveshaft bellow? I've heard of guys sneaking the bellow out the bottom. I noticed a small water leak today and it looks like the bellow
Thnx
rivermonkey is offline
Old 05-12-2011 | 08:59 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I've replaced all the bellows w/o removing the bellhousing. Never considered it a pain. Didn't want to risk damaging the hinge pins threads.
US1 Fountain is offline
Old 05-12-2011 | 09:14 PM
You might be able to do it but it sure is a lot easier to go ahead and remove the bell. You wil spend a lot more time trying to do it without removing the bell. All you have is 4 screws in the trim limit and sender to remove and then the 2 hinge pins. Not sure of the size wrench for the hinge pin on a bravo but my TRS you can use a 1/2" allen wrench. Remember you also would have to remove the old bellows and that aint easy. Their glued on tight. You would be sorry you even tried to do it that way.
picklenjim is offline
Old 05-13-2011 | 05:35 AM
The wrench you need is a 12 point allen or a socket you can buy from most any mercury dealer
Drock78 is offline
