What is a mounting stud ? >
Old 05-15-2011 | 11:03 AM
Default What is a mounting stud ?
When referring to a out drive, what is a mounting stud ?
pacalim1965@yaho is offline
Old 05-15-2011 | 11:09 AM
Stud for mounting the drive to the bell housing would be my quess. Ya got 6 of them.
http://www.perfprotech.com/store/ass....aspx#assembly
Part #2 in the diagram.
picklenjim is offline
Old 05-15-2011 | 11:41 AM
Yea thats what i originally thought also. But on the price sheet it says Mounting stud $4300.00 they might be referring to the whole upper drive. I'll figure it out thanks for your help. I appreciate it.
Any double threaded fastener, one threaded end stays in the mating part and you usually have loctite hold it in. The other end has threads also that you put the nut on to hold the two parts together.
Studs are great for assembly because you don't have to "find the threaded hole".
29Fever575sci is offline
Old 05-15-2011 | 03:18 PM
tcelano's Avatar
Studs are also superior in achieving a predictable preload, as you don't have to overcome tons of extra friction of turning a whole bolt. Also, it's better for aluminum not to move the bolt threads under load; let the nut/stud interface do that.
tcelano is offline
