-   -   Bravo 2 to bravo 1????? (https://www.offshoreonly.com/forums/drives-lower-units/253829-bravo-2-bravo-1-a.html)
Waterslinger 05-18-2011 07:50 AM
Bravo 2 X 1.5 gear set DIESEL for sale local and at a good price.
Will a 2 bolt up where a bravo 1 was? gimble the same?
How strong is it and is it a up-grade from a 1??
pros?? cons??
4bus 05-18-2011 08:01 AM
Bravo 2 lower will bolt right up to a Bravo 1 upper, it also bolts right up to the bellhousing or gimle, however I would verify that gear ratio.
http://www.bluewatermarinesvc.com/pd...ear_ratios.pdf
My cruiser came with a bravo 2, but now has a bravo 1 lower. I don't know the history or why it was changed, either damaged or the gear ratio was too low.
Bravo 2 has a different prop shaft than a bravo 1, props are very expensive and rare. I heard that TRS props will work but can't confirm.
Bravo 2's also have tractor gear ratios for big heavy boats, that is why I question the 1.5 ratio.
The gear set is stronger, and there is a ton of clearance between cavitation plate and prop, you can spin big wheels. However the x dimension is much much lower, going the wrong way on most speed boat applications.
A.O. Razor 05-18-2011 08:02 AM
pros?? cons??
What boat are you putting these on? They are very different drives. The B2 is made for slow cruisers, that run large dia. alu and ss props. They are nothing like the B1, and not a fast performance drive for sure. They don't share props, and they sit way deeper in the water and will slow you down. If you are looking for a replacement for a B1 lower and you want something less performance oriented with quick time to plane, easy to steer and with good midrange efficiency a B3 could be the way to go.
In other words. It's a downgrade imo. Don't replace a B1 with a B2. On a boat build for a B1, the B2 won't make any sense what so ever.
Waterslinger 05-19-2011 09:21 AM
Thanks guys thinking about a blower on the 496 ho mag in my 26 Velocity, knowing that the drive will get leaned on was just looking for something stronger. Deal or no deal looks like the B2 is not the way to go.
Johni_o 09-05-2011 01:56 PM
pros?? cons??
If you still have the Bravo 2 gears. Give me a call. 724-963-six nine nine zero. Johnny
