Imco SC won't go all the way in >
Old 05-22-2011 | 03:04 PM
Default Imco SC won't go all the way in
Help,
Freshened up the motor this winter and installed the new
XR red dot gimbal bearing. Engine alignment seams good. alignment tools goes in easy and the grease marks look good. the new Imco SC input shaft has 3 O-rings and my old B1 only has 2.
My problem is the old B1 installs without any problems.
The new Imco stops just as it hits the 6 bolt treads. Shift cable is in and looks OK, I turned the prop shaft as i was install the Imco Drive, but still stops just before the drive goes on the treads. is there a differents between the input shafts besides the third O-ring.
The boat is a 1998 Daytona 770HP, Everything i read said
it should go on. Going to call Imco in the morning and retry
next weekend
61vette is offline
Old 05-22-2011 | 03:33 PM
fireboatpilot's Avatar
RIPSTA Racing Team
One of mine does the same thing. i had to pull it in the rest of the way with the nuts. Seems like the studs are binding up on the housing.
fireboatpilot is offline
Old 05-22-2011 | 04:01 PM
The Imco drive stops just before it touches the treads, i've
pulled out the drive made sure the U-joints were lined up and
the shift cable was lineup and then had a friend help the second time, also using a drive stand. After fighting with it for a hour i put my original B1 back in and it went right in no problems.
61vette is offline
Old 05-22-2011 | 04:23 PM
My teague did the same thing when i had it out for a while. Might be the new o-rings, did you check engine alignment, did you grease the shaft
firehawkcat is offline
Old 05-22-2011 | 05:24 PM
Engine alignment is good and i did grease the shaft and
O-rings. But the O-rings have been on the Shaft since i bought
the drive last year, they are new but been on the shaft in the box for 9 months. I do have a new set of O-rings I'll try next weekend. Do I need the third O-ring since my old B1 only had two?
61vette is offline
Old 05-22-2011 | 06:36 PM
Mine is tough going in also. I use my drive stand on wheels, get it lined up and the input shaft started in the coupler, then give the stand a good swift kick. Sounds crude but it goes all the way and bottoms out. If I dont do it like that I need to pull it in with the studs.
Philm is offline
Old 05-22-2011 | 09:28 PM
I had turn turn over motor with a breaker bar and she slipped in and my alignment was good also might of had the angle of the dangle wrong but it worked for me. Drive gets heavy when it doesnt slide in the first time
Old 05-23-2011 | 07:50 AM
Thanks for all of your help, going to try on friday.
61vette is offline
Old 05-23-2011 | 08:28 AM
Also, gimbal bearing needs to be perfectly straight. They do move alittle in there, making it hard to line up. I usually use just the end of the alignment tool move the bearing around alittle.
kreed is offline
Old 05-23-2011 | 06:56 PM
Mr Gadgets's Avatar
Charter Member #601
Make sure you are not forcing the crank forward in the engine. It will make short work of the rear main thrust surface and the rest of the engine, so I have been told..
Dick
Mr Gadgets is offline
