Need help ID'ing this... >
Old 06-01-2011 | 08:51 PM
You got a pic of the entire trans?
picklenjim is offline
Old 06-01-2011 | 09:17 PM
No its still in the boat...
I did pull these numbers off the side...
10-05-065-901
not sure what that means, there was also a WG and a DIV cast into it as well..
bigo181979 is offline
Old 06-01-2011 | 09:45 PM
Well after doing a bunch of internet searching looks like I missed the tag on the trans... does anyone have a good pic of the trans ID tag on a B.W. trans..
Old 06-01-2011 | 09:59 PM
Originally Posted by bigo181979
I guess what I want/need to know is are these the same as a Borg Warner 71c or 72c or any velvet drive trans or what...
Yes I believe a Borg Warner transmissions are the same 71c has one forward clutch plate and 72c has two forward plates, (I believe) I had a 1987 400 with a Borg Warner 72c, should be interchangeable! I have a #2 speedmaster if you need one. Hope you find a trans soon
abones is offline
Old 06-01-2011 | 10:29 PM
Tag will be on the port side towards the front facing up. If it's a red tag and the model number starts off as 10-17 than it's a 71c. If it's a green tag and the model number starts off as 10-18 than it's a 72c.
Is it possible that ID tag is for the engine? They did make the 400 cyclone from '80 to '86.
Old 06-02-2011 | 06:49 AM
Mbam's Avatar
Offshoreonly Advertiser
Most likley thats a 72 series. You need a 1018-014. The part that connects to the drive comes from Mercury. That should be easy to find here, if not we have a bunch of them rebuilt with new bearings & seals ready to go.
Mbam is offline
Old 06-02-2011 | 09:10 AM
Do you have a left or a right rotating ssm II?
The tag is on the bell housing for the trans, So I am guessing that its for the bellhouse not the trans, I am gonna go double check and see if I can find a tag on the trans it self tonight. The motors are Mark IV 502's.
Old 06-02-2011 | 01:54 PM
[QUOTE=bigo181979;3418406]Do you have a left or a right rotating ssm
Left Hand, I ran two L/H rotating drives on and older cat, they are stronger by design!
abones is offline
Old 06-02-2011 | 05:05 PM
[QUOTE=abones;3418645]
I have 3 left hand drives, and 1 left hand prop and 1 right hand prop. I'll probably just end up selling a bunch of other parts and buy a new left prop...
Old 06-02-2011 | 05:09 PM
JasonSmith's Avatar
Sell them all & buy these:
http://www.offshoreonly.com/classifi...o38889-en.html
JasonSmith is offline
