Surface drive propshaft height on twin engine cats >
Old 06-19-2011 | 11:19 PM
Default Surface drive propshaft height on twin engine cats
Hey guys im just wondering if anybody has a rough idea about what height a twin engine cat would have the propshafts in relation to the bottom of the boat in full surface mode with #6 style props? imcos new scx surface drive looks very promising and id like to research where the typical drive height is with #6 cleavers in full surfacing mode.
JasonKelowna is offline
Old 06-21-2011 | 10:44 AM
Anyone?
Old 06-21-2011 | 01:26 PM
Read my thread and it will help. Most 2.5 inches above.
SkiDoc is offline
Old 06-21-2011 | 08:46 PM
fireboatpilot's Avatar
RIPSTA Racing Team
I was running with 2 3/8" above, Imco SC's w/ -2 shorties. Boat hooked up great and got right up on plane. Started to loose it's bite over 100mph and got real loose in the azz. Felt like it was ready to spin out. Also had some porposing issues. Spaced it down to where it's running 7/8" above and it's stable up to 115mph now and the porposing is much better. Still playing with props and gearing. Should have another 10-15 mph in it but it feels alot more stable now.
fireboatpilot is offline
Old 06-22-2011 | 05:32 AM
Fireboat, Longer skegs are needed for most hulls at 120.running over 2 inches above. Probably not a good feeling.
SkiDoc is offline
Old 06-22-2011 | 09:56 AM
RIPSTA Racing Team
No, it wasn't a comfortable feeling at all. So we'll run with it like this for now. Saving up for the SCX uppers then I'll use the SC -2 shorties. Who can do the skeg lengthining and how long should they be extended. Interesting idea. I actually picked up speed by installing the spacers but I think that its more because of the stability and being able to push it farther and longer than it is mechanics. I think by lowering the prop depth that I should lose speed? This sounds like I should start a thread about this? THANKS!
Old 06-22-2011 | 08:46 PM
2112's Avatar
Originally Posted by JasonKelowna
Anyone?
IMHO, you need to talk to the boat manufacturer. They most likely have the data you need or can get you into the ballpark so you can proceed with your own R&D.
2112 is offline
Old 06-22-2011 | 10:09 PM
IMCO is coming out with a SCX based surface drive. There was a pic of it over on performance boats as it was being tested. It is basically a SCX drive with a -4 lower and a modified upper that is designed to fit a 17" #6 style prop. This looks like a great setup for Bravo style boats.
Darrell.
DMOORE is offline
Old 06-23-2011 | 05:12 AM
Imco makes lower cases with extended skegs. So you can buy them for the SCX.
One of the reasons you may have been better off at a lower depth was that at a lower depth you can leverage the bow. In some cats that helps.
SkiDoc is offline
