king cobra water pump need help!!
I have king cobra drives and just put in a new motor because the motor had a blown head gaskit now I have good water pressure coming out of the impeller but the water is not making it to the motor! when I take the 1/14" hose off at the motor there is barely any water comming out there are no clogs when I take the garden hose to it with the pump housing off water comes through fine and when its all put together and running there are no leaks except at the very bottom of the drive there is a pee hole that is shooting over to the other drive?????? and no water comming out the exhaust any one have any idea
Check the impellor again? remove the cover on the KC drive & remove the impellor housing---its probably melted. Back flush the oil & power steering coolers. Its has to be one or the other.
Worst case the coupler is shot & not spinning the drive & impellor?
picture of the pee hole?
