milky tan goo
Old 07-06-2011 | 09:36 PM
Default milky tan goo
Took my boat out all forth of july weekend and on mon night I noticed this strange goo all over the drive!
So I pulled the drive and this is what I found !!
any ideas here?
Attached Thumbnails milky tan goo-photo.jpg-2.jpg   milky tan goo-photo.jpg-3.jpg   milky tan goo-photo.jpg-5.jpg
FORMULAfast is offline
Old 07-06-2011 | 09:50 PM
Gear lube mixed with water, just need to figure out where water is getting in.
firehawkcat is offline
Old 07-06-2011 | 10:24 PM
Ted G's Avatar
More than likely your prop shaft seal is failed and allowing water into the drive. This causes it to overfill and push out the input shaft seal. Any shop that does drives can pressure check and find the leaking seal(s). If you caught it early enough then it will need to be resealed and you're good to go.
www.cbpba.com
Ted G is offline
Old 07-07-2011 | 05:34 AM
Default pressure test
Ok thanks getting it pressure tested today to figure out what went wrong...... thanks again
