Replacing Bravo input yoke.
Need some expert assistance.Dick you still around?Been a while.
Need to replace the input yoke(short splined shaft with uni-joint)in the top of an XR Bravo.I have removed old but need to know whats involved in reinstalling.
I would install the new style retainer nut and seal and if you are running stock power just set the rolling torque for the bearings and torque the spanner nut. If you are running 650 hp and up you should hard shim the bearing set.
