Alpha I Trim Problems
Anyone had issues with the trim motor on an Alpha I trimming the motor down, but not up? It'll go all the way down, but only clicks when I try to trim it back up? Please Help..Boat is stuck in the water. I can't trailer it as is..
You need a new solenoid on the pump. Does your pump have 1 or 2 solenoids on it? If it has 2 then it's the one with the blue wires going to it. As US1 Fountain said jump a hot wire to the heavy blue wire that comes out the top of the motor on the pump to get it up for now. If your careful you can jump a screwdriver across the solenoid between the heavy red and heavy blue wire terminals.
