left hand prop on right hand drive >
Old 08-06-2011 | 11:48 AM
Default left hand prop on right hand drive
I was told that i could run a left hand prop on a right hand drive just for testing a prop just have to run rev for forward forward for rev .
will this work and will it hurt anything?
thanks
robby dmax is offline
Old 08-06-2011 | 12:00 PM
Bravo drives spin either way. They are not LH or RH specific.
Yes, you can just run it in reverse to go forward. All you have to do to make it permanent is switch the cables on the controls.
Griff is offline
Old 08-06-2011 | 12:06 PM
griff
thank you for that info just got a loaner prop and it is a left hand and mine is a right so i just never heard that you could do that
so thanks again
rob
Old 08-10-2011 | 01:33 PM
So is it "good practice" to switch the forward drive direction on a used/seasoned drive? Seems like the gear mesh has already been "set" so to speak, and reversing the forward drive direction could cause an wear issue?
Making a lot of assumptions here - so please elaborate.
I'm finding a lot of LH props that I'd like to try, but they are counter-rotation.
Thanks.
ALL_IN! is offline
Old 08-10-2011 | 09:58 PM
Thanks.
Spinning a left hand prop puts pressure on the top cap...not a problem if you have a good cap. Otherwise it is like using a new set of gears as the faces are fresh. You can stay with the same prop and flip the upper gears around to accomplish the same thing.
JRider is offline
Old 08-11-2011 | 01:51 AM
It will not cause any issues to run the drive the opposite direction.
Keep in mind, many single engine boats do not run/handle the same with a LH prop.
Griff is offline
Old 08-11-2011 | 05:51 AM
will they run faster? fly different?
Drock78 is offline
Old 08-11-2011 | 02:23 PM
They will lean and pull to the side differently. Some boats like them and some don't.
Griff is offline
Old 08-11-2011 | 04:05 PM
I have noticed most single engine fountains have LH props. My 24 Cigarette also ran a LH rotation TRS. The boat handled really well with no lean at all. It flew very predictably also
I know this was implied by griffs posts, but we are talking about a Bravo drive, right? You don't want to run a TRS, etc. in reverse or you will smoke the trans. Just want to make sure we are all on the same page.
RT930turbo is offline
Old 08-15-2011 | 12:42 AM
tcelano's Avatar
Yes. Anything with a Borg Warner transmission cannot be run at power in reverse. I think the sound alone would stop most folks.
tcelano is offline
