Time for Arneson upgrades? >
Old 08-17-2011 | 07:52 AM
Default Time for Arneson upgrades?
Anyone looking to upgrade from Bravos to Arnesons there is a set of ASD 7 conversion kits just listed.
Slug-ger is offline
Old 08-17-2011 | 08:02 AM
Good price for them too.
Philm is offline
Old 08-18-2011 | 10:37 AM
Great price & low hours.
Slug-ger is offline
Old 08-20-2011 | 06:27 AM
Send me a PM on details. Sent you e-mail
laszlo01 is offline
Old 08-22-2011 | 09:29 AM
Didn't get the email. ASD 7s with bell housings pressure plates, transmissions, complete set up.
Slug-ger is offline
Old 08-22-2011 | 01:25 PM
Yep, and if you're running really big power, there's a set of #14's
A.O. Razor is offline
Old 08-22-2011 | 01:40 PM
Ive wondered what these would do to my Stiletto
drpete3 is offline
Old 08-22-2011 | 02:33 PM
Make it bulletproof on the drive end of things... But also make it a little dicey for swimming off the back of the boat. From what I understand because of the lack of parasitic power loss compared to a conventional drive, a lot of guys see about 7-10mph with the conversion too. Props are pricey though! 10K for a set of Herings if you decide to go the cleaver route. There was a thread on here about a guy who did the conversion to his 38' Formula... If I remember it went pretty well.
northerndoc is offline
Old 08-22-2011 | 02:49 PM
I certainly would not want to see my little guy cannonball onto those props!
drpete3 is offline
Old 08-22-2011 | 05:16 PM
It's not so much about parasitic loss. The Arneson has a tranny, versus the build in gears in a bravo. In a #6, well that's another story. There you have a tranny that goes to input shaft, into two vertical shafts with gears, into propshaft that is driven by the two shafts and sets of gears + plus the oil pump, that circulates the oil in the dry sump lower case. Many moving parts and more weight in a #6 compared to an ASD. Arnies and Bravos are more about less drag and efficiency. I know, a little of the same thing. It simply boils down to the fact that, surfacing props and no torpedos under the water, is much more efficient. Also, surfacing cleavers bite harder and has less drag too, than the bravo style props.
