Imco Lower
Old 08-20-2011 | 02:10 AM
Default Imco Lower
Can I purchase a stock length empty Imco SC lower and put in stock Bravo internals instead of an XR?
I know a lot of people on her are going to tell me it's a bad idea but I've had over 15 years of running including 10 poker runs using the Bravo's from 92 with out breaking gears/shafts. This is with 500 hp and ft/lbs of torque through the drive. I've had the drives once to be gone through and all they required was a seal kit, this was last winter.
I've witnessed and heard horror stories from people with new XR drives and I'd rather like to avoid it as I suspect Mercury is using lower grades of material in the gears now.
I also have 5 Bravo's complete sitting that I can use for parts if anyone of mine fail, so I'd really like to stick to the stock parts if that is at all possible.
Anyone done this yet? I know with some modifications you can mount a sportmaster to a regular bravo top half, and our local performance shop (not a small time shop but to stay anonymous myself I won't mention them at this point in time) has told me to avoid the XR and just use my spare uppers if I blow one anyways.
Kings11 is offline
Old 08-20-2011 | 10:36 AM
What are you trying to accomplish? Do you have blowout issues at high speed? If not, it'll most likely slow you down. Switching should not be a problem though.
A.O. Razor is offline
Old 08-20-2011 | 01:21 PM
New boat, it had nose cones previously for 500HP as it had blow out issues.
It's a 30' Regal Velocity, I'm going to put my standard Bravo's on it to start, how ever if I encounter blow out as is expected from the previous owner, I will be doing this swap over the winter if it's do able.
Kings11 is offline
Old 08-20-2011 | 02:07 PM
How fast do you expect to run? My experience is, that blowout usually don't occur under 85-90 mph. Maybe prop testing and setup could be the answer. It is doable, give IMCO a call, they will tell you what, if anything, you'll need to replace.
Old 08-20-2011 | 02:48 PM
articfriends's Avatar
As long as you use the right vert shaft lower bearing and race on the vert shaft you could put ALL stock internals into a std length Imco lower, Smitty
articfriends is offline
Old 08-20-2011 | 05:44 PM
The boat previously ran a best of 92 mph on GPS with 4 blade 30 pitch Bravo's. This was with 550hp 496ci big blocks. With standard drives, that were nose coned. I'd rather just buy a case already with a nose cone instead of dealing with the problems/head aches due to the Canadian winters that seem to occur on a frequent basis.
I am putting in my 427ci small blocks making 510 HP as a start piece so I can have the boat at a poker run in the next week.
Kings11 is offline
Old 09-08-2011 | 08:43 AM
Took this advice and slipped the boat in finally last night. I believe I have it over propped, but due to the engine bay being so long I can't time it, for proper rpms, and the gauge I was using kept falling off once we hit some waves.
I'm hoping my tach adapters show up today as they were stuck in Canadian customs, that will make this a lot easier.
What I did get though was 4600 rpm if I believe my tool. I'm going to try again with the tach adapters (I want to run 5500 for these motors), and 80 mph on gps.
Kings11 is offline
