-   -   driveshaft to flywheel (https://www.offshoreonly.com/forums/drives-lower-units/260853-driveshaft-flywheel.html)
weldcrane 08-22-2011 08:42 PM
what is the best way to to make the connection between the flywheel and driveshaft to absorb some of the torque ?
weldcrane 08-23-2011 06:06 AM
somebody has to have some info on this
fireboatpilot 08-23-2011 07:11 PM
Stellings and I'm sure Imco has what they call drive savers that bolt directly to the flywheel and the shaft flange bolts to the drive saver eliminating the coupler.
I didn't like that idea so I fould a pair of driveline bellhousings and transmission eliminators so that I could retain the couplers and soften the impact on the drives while shifting then I just shortened the shafts accordingly. So far works like a charm.
PS- I have a pair of the drive savers if you need them, $125. shipped to lower 48
weldcrane 08-23-2011 09:31 PM
thanks but merc makes a complete kit i ordered 2 sets today nomore driveshafts to flywheels
