Bravo 1 Drive
Old 08-22-2011 | 09:04 PM
Default Bravo 1 Drive
OK I had a Mach Stern Drive Prop 14 3/4" 18p. and WOT was 3100 RPM and boat would stay up on plain. I swapped to an aluminum 16" 16p and boat got up on plain, and WOT went to 3900RPM any Help would be Appreciated.
ooops sorry I have a BB 454 with a Bravo 1, 1.5:1
TraumaRN is offline
Old 08-23-2011 | 02:10 AM
what size/make boat???? Those are little props.
Griff is offline
Old 08-23-2011 | 11:59 AM
Sea Ray 27' AmberJack BB 454 and Bravo 1 with 1.51:1 gear set. Thanks Bill
TraumaRN is offline
Old 08-24-2011 | 09:15 AM
Bill the Nurse- I don't understand your concern?
First- it is "plane" not "plain"
That engine should run at 42-4600 RPM WOT.
If you want the best over all performance a Revolution 4 blade 15P is the solution for a cruiser of your size with a single BBC. Call Brad at Bblades, they even have a trial program on the props.
4bus is offline
