Cavatation Burn
Old 08-24-2011 | 04:54 PM
Default Cavatation Burn
So I am getting some cavatation burn on both sides of my outdrive. It is rite behind my water pick up. I was told that it is from air bubble actually burning and eating at the drive. So i took a piece of sand paper and sanded it just in case there was some burs or something. What else could really cause this.?
98Fever27 is offline
Old 08-24-2011 | 07:47 PM
the cavatation cant be good on the drive, what kind of prop
firehawkcat is offline
Old 08-25-2011 | 04:46 PM
I am running a 26p mirage. It was lab finished and now it need to be redone. I know it cant be good for it.
Old 08-25-2011 | 08:31 PM
My cat was real bad with cavatation until i put a bravo 1 prop on
Old 08-25-2011 | 08:32 PM
I have heard of the air bubble burn before thought it was bull until you posted
Old 08-26-2011 | 06:45 AM
CigDaze's Avatar
Cavitation burn is no joke. Over time, it can eat right through and does wonders for streamlining waterflow.
It occurrs in areas of extreme low pressure, usually behind some kind of protrusion - like water intakes, or just behind leading edges or drives and props. This low pressure actually "boils" the water turning to steam very briefly. When it returns to its liquid state the implosion of the bubbles erodes the metal because they're actually mini sonic booms.
Check out this photo. The "air" you see is not really air sucked from the surface, rather it's water turned to steam right behind the leading edges of the prop where the lowest pressures are seen.
CigDaze is offline
Old 08-26-2011 | 07:27 AM
It's eating my Imco w/Bravo 1. Word on the Donzi forums is that there is not a thing I can do about it.
thirdchildhood is offline
Old 08-26-2011 | 09:05 AM
I have the same burns just like you described
Griswald is offline
Old 10-17-2011 | 08:20 PM
So how do you take care of cavatation burn?
Old 10-18-2011 | 08:58 AM
Mine is getting worse. I wonder how thick the aluminum is there. Pic is in post #7, now it is twice as deep .
