max throttle rpm
Old 11-29-2011 | 09:00 PM
Boater8987's Avatar
Airking
Originally Posted by MASOMAN
Boater8987 You are correct all the 454 alpha packages from merc came with the 1.32 gear ratio.
Thanks. That gives me hope. I can still remember something from 24 yrs ago.
Boater8987 is offline
Old 11-29-2011 | 10:12 PM
Aha, then it all makes sense. I thought the 1.32 only came on the Alpah SS. Well you learn something everyday. And in that case, your slip is 7%, and that is about as perfect as a slip on that kind of hull gets. Labbing your prop could be an option. The 454/330 is build to run between 4200-4600 rpms, so you are not far off and pretty much out of puff after 4600 rpms.
A.O. Razor is offline
