Bravo I - Gimbal Ring & Steering Pin >
Old 09-20-2011 | 11:46 AM
Default Bravo I - Gimbal Ring & Steering Pin
It appears that the steering pin and gimbal ring are getting a little loose and I am taking on a little water.
I thinking both the steering pin and gimbal ring both need to be replaced, correct? From what I have read, the steering pin wobbles out causing the gimbal to wear. Is there any advantage to going with a stainless steel gimbal ring as opposed to a stock cast aluminum gimbal?
The boat has a bravo I drive and is just short of 650 hp.
baja_brian is offline
Old 09-20-2011 | 12:40 PM
No. not the ring, it's your housing. The seal area. We fix those so you don't have that problem. But you must remove the complete Gimbal from your boat. Give me a call at:
954 237 0332. Ask for John
John the Drive Man is offline
