-   -   IMCO SC rebuild (https://www.offshoreonly.com/forums/drives-lower-units/262745-imco-sc-rebuild.html)
38 GoFast 09-21-2011 05:40 PM
IMCO SC rebuild
So I'm throwing this out there on how many different dollar amounts I get on this. Case's are perfect. needs full upper and lower 1.50 gear set. All bearings/races, seals, u-joint, upper drive shaft, and clutch. $5600 plus tax per side. Is this reasonable or out of line. Does it really need to have everything replaced after 1 tooth sheared on upper? 1st time for me on this and not sure if I'm being taken for a ride or if this is a reality check?!? I know the other side is going to go soon and may not need all parts but the bid was worst case on other as well. Grand total: $11396.00 plus tax.
fireboatpilot 09-21-2011 06:01 PM
Rarly does a tooth come off at speed and not do damage to something else in the drive. Also depends on how much metal was circulated thru the drive and how worn where the other parts before it went. If you know the other side is going soon, I assume there are alot of hours on them? There's about $3500+ in parts there that you mentioned for the one side. The thing with the SC's is that they are basically only XR's with a beefier casing and a replacable upper tower. I think your definitly at the upper end of the price range though and could try to negotiate it down a bit, $10K is a nice round number. And get your used parts back for spares, at least the gear sets that are not blown. Might save a season some day.
offshorexcursion 09-21-2011 09:29 PM
I blew my SC's and needed everything including a vertcal shaft in one and my quote for the pair was less then yours!
Talk to "Mr. Gadgets" on here. Dick specializes in imco sc's and will take good care of you. 616-403-1006
Good luck.
How many hours, boat, engines, Hp/tq?
mike tkach 09-21-2011 09:51 PM
Good luck.
I AGREE,he will do it right and at a fair price
articfriends 09-22-2011 12:32 AM
With all the upper gear failures if you pay the long dollar make sure you get some kind of warranty if possible, Smitty
38 GoFast 09-22-2011 11:26 AM
Well they are in process of breaking down the other drive to give me a more tollerable amount. They took some off of their parts mark-up this am and said they would possibly take another couple hours off the un-broken drive since it's not locked up and full of metal. Were looking at about $9500-$10,000 now depending on what they find today. I hope this puts me in the ball park on what it should be by all of this thread's readers. Long dollar gets me a 90 day warranty starting in spring.
chewymalone 09-22-2011 12:30 PM
should be less than $3K each.
fireboatpilot 09-22-2011 02:14 PM
You'd be lucky to get the upper and lower XR gear sets for $2500. for the pair, each side. How you gonna do bearings, seals etc including labor for $3k per side? Verticle shaft and tower for sure in the blown one too. tell me who's doin a complete new rebuild on an SC for 3 grand, I'll have work for him, been blowing about 3 per season. Can't wait to get the SCX's
38 GoFast 09-22-2011 02:59 PM
Fireboatpilot is correct on cost of parts unless someone knows of a supplier thats cheaper. I priced the parts for the blown side complete it was right at $3900 on two different sights. Give or take a couple hundred and 8 to 12 hours of laber depending who you talk to, and I think I'm there unless I'm missing something? Which brings me back to why I'm asking people that have been around this block before...am I?
offshorexcursion 09-22-2011 09:47 PM
Sounds like your price is close to fair. What about selling your uppers used and broken and upgrade your uppers to SCX and rebuilding your sc lowers?
38 GoFast 09-23-2011 09:34 AM
Unfortunately not in our budget this year, but than when are problems in our budgets. Is it always the top half that goes on these SC's and how much hp are these really rated for compared to the SCX upper and SC lower?
offshorexcursion 09-23-2011 11:46 AM
IMO scx is rated for about 800 and the sc 650. Scx combo sc lower will just wear out your lower gears every 50 to 150 hours depending while the scx upper has lasted behind 800 hp 450 hours so far.
fireboatpilot 09-23-2011 02:57 PM
best price I found so far is $10K per side for 1 SCX upper with the new bell to use it with the HP gimble, plus figure in a little more for rebuilding the gimble since it's that far apart already. So $24K to change over to SCX uppers. my lowers are fine but I do need to swap in the 1:36 gears. I'm running 36P 4 blades and need more prop still.
