2 Part Question on Alpha One's >
Old 09-26-2011 | 07:23 PM
airshares's Avatar
Default 2 Part Question on Alpha One's
1) To upgrade from Alpha one to Bravo 1 do I need to replace the gimbal as well or just drive unit?
2) Where can I get the service manual for Alpha drives?
airshares is offline
Old 09-27-2011 | 12:03 AM
you need to replace the gimble its actually pretty simple, however if you dont actually need the bravo the alpha will be a little faster.
phragle is offline
Old 09-27-2011 | 01:14 AM
Do you have an Alpha One or an Alpha One Gen 2 ? Do you know the serial number ? I have them both in PDF. PM me an email adress and I'll send them to you.
What engine you running?
picklenjim is offline
Old 09-27-2011 | 10:28 AM
airshares's Avatar
Default Alphas
I have Alpha one gen 2. Engines are stock 350 mag.
I do have the serial numbers.
Old 09-27-2011 | 10:40 AM
Rookie's Avatar
I wouldn't be to concerned about running the alphas on a twin smallblock application in a 6000lb boat. Not that it is a direct correlation but 3000lb/drive behind smallblocks. They have lasted 14yrs so far. Just take care of them. If you start having issues and replacing them every year or add power....then ok. I have seen a 32 Pachanga with big blocks that the alphas have lived behind.
Also I am no drive expert so take it for what it's worth.
Rookie is offline
Old 09-27-2011 | 09:04 PM
airshares's Avatar
Default Thanks Rookie and Jim
I am happy with the Alphas. People in the past have kind of made me think the bravos were superior. But for my application. I think you are right. Im Sticking with them.
Thanks for PDF file of the manual Jim!
