rpm limit of bravo 1 >
Old 09-28-2011 | 11:26 AM
Subscribed.
Wasted Income is offline
Old 09-28-2011 | 11:47 AM
I'm doing a ls6 intake and maybe next year lq9 heads to get 550 out of the motor Idk yet maybe I'm rebuilding the boat now picked the hull up for 300 doing stringers bulk heads floors and a new transom then put all my junk in the boat doing a suburban harness and pcm custom tune and trying to get my new to me 2008 Corvette z06 cluster to jive with the boat want something different everyone has around me
stroker331 is offline
Old 09-28-2011 | 12:40 PM
just a lil more info for ya. my Motor on the dyno made 568 peak at 5400. I currently have a 24 pitch bravo prop that has been worked with alot more cup. and i can spin it to about 53-5400 and it runs 70mph. i thought id have been able to spin it much higher, but i guess the hull design has alot to do with that. Seen alot of boats with less power than mine run faster. Good luck with the setup. I have several friends that are big with the LS motors and have considred if my my motor ever really granades that would be a real good idea. Personally i think id have to stroke it. since tq is more needed than top end hp in a boat. Trying to make too much hp at a high rpm wont give you the results your looking for. Keep us posted and id love to see pics once ya get it done.
spark plug is offline
Old 09-28-2011 | 01:21 PM
Your Z06 cluster likely won't work since it's driven off of a CAN body control module, and you will likely be using an 0411 PCM to run your engine...they won't communicate. My advice is to ebay the cluster and get some decent aftermarket gauges, or find a BCM and cluster from a C5 or an earlier pickup or F-body.
Old 09-28-2011 | 07:01 PM
I have done 7600 RPM 1:65 23 pitch drives lasted well at 610 HP
Steve
smiklos@sunprint is offline
Old 09-28-2011 | 08:12 PM
ok i run my at 5700 24 baja 540 dart motor n/a 718hp at 5800rpm bravo drive 136 mirage23prop runs over 80mph all the time put a 21pitch on went 6000rpm .i have a msd chip a 6000 no gain in speed but was a rocket ship getting to 80 was very fast getting there. o full tank and 5buddys still did 80 . now i run a 25mirageprop 5100doing 78.9mph crusing 50mph at 3200rph http://www.youtube.com/watch?v=jmnD9...f=mfu_in_order
bajabob is offline
Old 09-28-2011 | 08:15 PM
Steve
steve how fast are you going and wt boat do you have??
bajabob is offline
Old 09-29-2011 | 06:59 AM
That was back in the early 90's 30 Velocity B class boat. Max was 91-93 MPH (loran). 372 CI 12:1 drysump engines
Steve
