Drive swapping for even wear >
Old 10-04-2011 | 04:44 PM
articfriends's Avatar
Originally Posted by Brad Zastrow
I agree 100% I have a freind who blew the gears out almost the first time out after reversing his drives on his bravo with blower motors. Even the shafts can let go when you unwind them, so to speak.
Good point, if you twisted a shaft again and again and it springs back, like the max machine worx torsional memory shafts, if you started twisting it the other way I can't see any good coming from it, Smitty
articfriends is offline
Old 10-05-2011 | 09:36 AM
Remember all parts in a reman unit are not used. Only the housings are. The working parts are all new.
John the Drive Man is offline
Old 10-05-2011 | 10:50 AM
Maybe in a Merc reman, I have had cpo's units have used parts in them, but if you call around to rebuilders and ask what is new in their units most of them say only the parts that are bad.
waconda is offline
Old 10-06-2011 | 07:56 AM
That's what I'm referring to Merc. units. I would never use any other reman unit under no circumstances. You are asking for trouble.
Old 10-06-2011 | 09:53 AM
John CPO's are merc units.
I do agree that there are some reman's units out there to stay away from but there are some very good ones also.
waconda is offline
Old 04-28-2012 | 03:25 PM
Ok, I am installing a "gone through" Imco xtream sc and don't know if it is left or right. It's on the bench in neutral. If it is a left what harm would running a left prop be in a 25' eliminator daytona? Or can I just swap forward/reverse in controller and run in reverse for forward? From what I have just read it sounds like a crap shoot for the ladder. Is running a left prop so bad?
Never Enough II is offline
Old 04-29-2012 | 08:24 AM
mrquad1's Avatar
Originally Posted by Knot 4 Me
Bergers at LOTO recommends doing this as well.
jmo bergers need to close thier doors
mrquad1 is offline
Old 04-30-2012 | 12:59 PM
Knot 4 Me's Avatar
Wasn't endorsing it one way or the other. Just passing along what Mike Berger told me once in a conversation about Bravo Drives. I know plenty of folks that are glad their doors are open.
Knot 4 Me is offline
Old 04-30-2012 | 07:36 PM
MarkDonzi's Avatar
I tried swapping drives on my boat and promptly broke both of them within 2 days of each other. After talking to a LOT of people about it I found that swapping the drives is OK if you do it on a regular basis. Like almost every time you go out, otherwise you are asking for trouble.
I run amsoil in my drives changed every 20-25 hours with 600 SCI's and have to change the gearsets, bearings, etc. every 100 hours. Gears start to pit and then they are ready to break at any time.
Attached Thumbnails Drive swapping for even wear-112.jpg   Drive swapping for even wear-113.jpg   Drive swapping for even wear-110.jpg
MarkDonzi is offline
