Bravo 1 or Bravo 3?
I have a 90, 29’ Mach 1 with a single strong 502 and Bravo 1 running a 23 Mirage prop. I see many newer Baha/ Mach 1 boats running the Bravo 3 and am unsure if this would be an improvement or not for my boat and don’t know where to begin with prop selection for a Bravo 3.
It depends on what you want to do. If you want speed, go B1. If you want fast planning, easy docking, better handling and great mid range efficiency, go B3. You will loose 2-3 mph. Those you may be able to get back by labbing the props. But all things being equal, you can also lab your Mirage and so that'll still be faster.
One way to find out if you like it or not, is to get a good used B3 lower and bolt it on your current drive. No need to buy a new complete drive. Sell it if you don't like it, or keep both so you have an option, or can go back to B1 when you sell the boat. One thing to be aware of. The B3 was introduced in '93, so make sure what ever lower you get, it'll match your drive. What GPS speed @ what rpms are you running with the Mirage? What gear ratio is your drive? What is your x-dim? |
Bravo 1. I have a good friend that has a 91 with a built 502 and took the B3 off and gained 5mph and no loss on hole shot. He has kids and tubes/kneeboards/skis with the boat. As mentioned above, it all in preference but I wanted to share a little real world experience with that particlular hull and power.
Originally Posted by A.O. Razor
(Post 3521452)
If you get a B3 lower, you will also have to reverse the shift mechanism - B3s run opposite of a std single B1 (ie, forward on a B1 will be reverse on a B3). One advantage to teh B3 not mentioned is stern lift - I can hold plane at 12-13 mph (gps) with my B3 vs 20 mph for the same B1 equipped hull. And I plane out in <3 seconds (0-20 is 3 seconds). This is a great advantage to me right now as I have a 3 year old, so slow is good. Other advantages / disadvantages here are accurate IME.
You have a 22' footer with a BBC. If you need faster planing, play with props. If you really need the low speed capability, the B3 might be worth trying (and it can be resold for breakeven if you don't like it). My $.02 |
| All times are GMT -5. The time now is 09:49 AM. |
