-2 sportmaster lowers on B1's
Thinking about putting -2 sportmaster lowers on my b1 uppers. I am also doing billet top cap over the winter. What needs to be done/ changed to install the lowers?
Thanks in advance Curt |
nothing, and -2" shorties were the best thing i ever did to my mystique, picked up speed and handling
i would go with imco's tho, most claim there shape makes them a little faster |
Hi guys. How far below the boat were and how far below now are the drives below the boat if you guys know.
Ive heard the imco's were a little faster and sportmasters have better handling than imco. If I went with imco, is it still R&R or would I have to change/modify anything?
Allicat, not sure how far below mine are. Im going to switch my props and spin them in next week. Ill measure and let you know. I also have the notched transom, is yours notched?
No mine is a 2002 and is not notched. I have alot of blowout planing witch i hate. I wonder if a sportmaster type would help the flow of water to the prop. I also have reg. bravo 1 s with the 496s. With that i dont think a 5 blade would be wise though i think it would help. Ill measeure mine this weekend to. I did before but forget. Sounds like boomer has the setup if these boats all have the same x demension so all this info can be used for all 30s. I wonder if not having the notch is causeing the blowout. I have not used the boat much as i have been spending more time on the bigger boat but i really like this 30. I wish they were all stepped. I think i am going to play with props till i get rid of my bigger boat.
my boat is notched, which i think helps with shorties. My nose cone now is still below my hull, my guess would be about an inch,
no, whether you bolt and sportsmaster or an imco on, its the same... I had sportmaster standard length on my boat first, and they didnt feel like the handled any different then the imco... tho i have heard the same thing about handling being better with a SM, i think its due to sportmasters skeg being longer i have done a TON of testing with the mystique, and think i am finally close to the perfect set up, PM me if either of you guys want to talk and ill send you my number, Curt if you still have my number feel free to call one REALLY easy 2mph i will tell you guys is to cut 1/2 of your diffuser ring off. I have -2" and still have no problem getting on plane, so with your standard length it will be no problem.. easiest and cheapest 2+mph you can get. it cost about 60$/prop my mystique ran 90.7 last weekend. Some of it is due to the HP, as my motors have been bumped to about 600hp. but the other as just been testing... this was with stock 32p bravo 1 4 blades with 1/2 the diffuser cut off.. im hoping labbed will be give me a few more mph's |
Originally Posted by Allicat38
(Post 3522404)
well i guess none of us got nothing do on a friday night, then talk about are Mystiques.....Question...... can I bolt Xr drives to my bravo housings, without changing anything.....i found a used set of xr uppers with Imco-2 lowers....
Originally Posted by tcwcar
(Post 3522414)
| All times are GMT -5. The time now is 11:44 PM. |
