Changing Gear Oil
I am pretty disappointed with the manual gear oil pump I purchased this year to fill my Bravo 1 drives.
Looking for recommendations on what other people are using that is simple quick and clean.
1 gallon garden sprayer with the drive attachment from your pump kit attached to the end. I put about 3 quarts in the garden sprayer and watch the level as it slowly fills the drive. I'll even walk away for 2-3 minutes and do something else when it first starts to fill.
Here is what I use (bottom of link). Holds 3 gallons. I like the quick disconnect fitting that oil cannot pass through without the hose end attached. Do note that due to the diameter of the quick disconnect fitting you have to remove the zinc that surrounds the propshaft on Bravo I drives.
http://www.stevensinstrument.com/gearcase.htm
I bought a hand pump thing from wherever (WalMart, Marine Max, etc.) I bought a cheap garden sprayer & pit the hand pump end on the sprayer end.
Basically buy the 2 parts + a small on-off ball valve, 2 hose barbs and adapters (all from Lowe's/Home Depot) put them together & you've got yourself a drive-filler-upper.
