Need drive advice for Glastron CSS-19 project >
Old 02-09-2012 | 12:23 AM
if you decide to go with a bravo,i have 1 complete with gimble housing and inner transom plate,everything you need to install the setup.
mike tkach is offline
Old 02-09-2012 | 01:29 AM
Fenderjack's Avatar
Pirate of the Chesapeake
I would stick with the alpha. The boat is light, they put alphas behind BBC boats much heavier then yours. The HD alpha is/was made to go behind a BBC, from what I gather is a little bit stronger then the reg alpha. Still I would be easy on the hole shots. I ran one for 3 years in the 202 stinger with 365+ hp with out a issue, spun it to 5900 alot. Just my op, but a bbc would be more then enough, but would possibly change the ride of the boat, being a heavier drive. Alpha would be my first choice in that boat/power config.
John jr
Fenderjack is offline
