#6 wetsump drives
Old 10-21-2011 | 09:42 PM
Default #6 wetsump drives
question on wet sump#6 drive,when i pulled the drain plug i got some water,is this normal,and where does it enter the drive from?im new to # 6 drives.
mike tkach is offline
Old 10-21-2011 | 09:58 PM
Default wet
couple things, change propshaft seals, and change oring between upper and lower. no it should not have water in it.
Driveguy is offline
Old 10-22-2011 | 09:37 AM
thanks,that is what i was thinking was wrong,these drives make my xr drives look like toys.
Old 10-28-2011 | 11:10 AM
Probably the prop shaft seal......common issue. Call Randy @ Marine Drive Inc. 352-447-0309
CignificantOther is offline
