gimbal ring replacement is a plug kit ok or no?? >
Old 10-31-2011 | 08:34 PM
Default gimbal ring replacement is a plug kit ok or no??
94 29 foot scarab with twin 350 and 2nd gen alpha ones. I was greasing up the lower unit to get it ready for winter and found one of the grease zirts on the gimbal ring fell off in my hand because it is cracked at the up and down pivit point and seperated about and 1/8in or so. So i called around a few places and some places want to pull the motor and some want to use the plug kit. What are the ups and downs of these. Pulling the motor is about twice the money over all and my second though was if i had any problems in the future if used the plug kit i would alread have access haha.
chevytrucks94 is offline
Old 10-31-2011 | 08:44 PM
Check out jr marines kit. To me the merc plug kit looks like a joke. I used jr's and it was a piece of cake. Can you get the rest of the zert out if not might try a easy out before yanking the motor or drilling into the lower
firehawkcat is offline
Old 10-31-2011 | 08:50 PM
the whole zurt is out its cracked all the way threw and seperated so basically the zurt was just sitting in there
Old 10-31-2011 | 08:51 PM
where do i find jr kits??
Old 10-31-2011 | 09:07 PM
ok i found jr kit. That dosent look to bad as anyone used it and what are some feed backs on it? i says you need a wrench kit is that true or has anyone tried to use regular wrenchs??
Old 11-01-2011 | 01:42 AM
If the gimbal ring is cracked, then it needs to be replaced.
Plus, the JR Marine kits are for Bravo drives.
Griff is offline
Old 11-01-2011 | 06:20 AM
That's what I am getting at is how to replace it?? You have to get to the steering nut that I am told can't b done unless u pull motor do plug kit or the jr marine kit. And when u search the jr ki it says its for bravos and alpha 1 secind gen
Old 11-01-2011 | 07:22 AM
No experience on the 2nd gen Alpha 1, but I did my bravo with the JR method. Went pretty easy, and quick. You'll have to replace or repair the gimbal after you get it out.
apollard is offline
Old 11-01-2011 | 07:38 AM
In the past used the merc plug kit.We now just pull the motor,seems easier and faster for us. hf...
halffast is offline
