800hp 1:36 gear on a kv >
Old 11-30-2011 | 07:06 AM
Default 800hp 1:36 gear on a kv
im going to from a 1:50 to a 1:35 imco sc standard legnth drive on 38ft scarab kv. please give any input on the pro's and cons of making this change. im more interested in a good cruise speed (thats not why i did the deal) so what props to start with? its a done deal so no talking out of.....i have to make it work. thanks in adavance!!
MrSneakAttack is offline
Old 12-02-2011 | 10:50 PM
the main reason to go from 1,50 to 1,35 is if you are allready at a 36 pitch prop.in my opinion ,with a pair of 800 hp motors,1.35 gears is a good idea.
mike tkach is offline
Old 12-02-2011 | 10:52 PM
what props are u running with the 1.50 gears?
Old 12-03-2011 | 05:14 PM
i did this to my24 baja with 718hp midrange big improvement 600rpm less then 150 gears3000 rpm i am doing45mph at 5600rpm doing 81.9 so far still tweaking
bajabob is offline
Old 12-03-2011 | 05:31 PM
34 bravo's at 5500 rpms.....the boat has boxes so my slip is a little high at 21% or is this normal with boxes and should i try 5 blades? still learning the boat but the boat feels good and everything feels right so over trimming is not a concern...
Old 12-03-2011 | 05:34 PM
dang you have baja in the wind huh ...thats rollin for that boat...good job
Old 12-03-2011 | 06:02 PM
5 blades should reduce your slip.
Where are propshafts in relation to the bottom?
Am I correct in assuming the boat is running around 90mph currently?
MILD THUNDER is offline
Old 12-03-2011 | 06:21 PM
never measured but it looks like about 2 inches below the bottom of the boat...90mph is corrrect light and right
Old 12-03-2011 | 06:23 PM
Default fixx
5 blades will tighten things up a bit but that kind hp and a 5 blade may kill the drive,,would rather have some slip
FIXX is offline
