bravo one drive
Old 12-24-2011 | 07:20 AM
Default bravo one drive
can you put an{older bravo} bravo one upper with out the oil hole on a{newer bravo} bravo one lower with the oil hole thanks mike
mikeoutlaw24 is offline
Old 12-25-2011 | 08:55 AM
Mr Gadgets's Avatar
Charter Member #601
That will block off the flow to the upper pinion gear bearings.. On the old upper there is an extra hole in the main vertical shaft cavity. You could plug the upper, or if the lower has an island with no hole, then add the quad seal and it should block it off.. but you need to duplicate the oil transfer hole in the old upper.. Not the best way to do it.. I would look for a newer lower case. there are many out there on the used market..
Hope that helps.
Dick
Mr Gadgets is offline
