Trs trans
Old 02-05-2012 | 08:19 AM
Default Trs trans
I have a trs drive with merc trans just pulled motor and the bell housing was a little wet with fluid here is a pic,is this easy to change the shaft seal my self any input would be great
justbassing is offline
Old 02-05-2012 | 11:32 AM
Very easy. Just remove the small cover. The hard part will be finding a seal. Most likely you won't be able to get one from merc. You can get one from some place that sells bearings and seals though. Also there's an o-ring on the cover you will want to replace. # 21 in the diagram.
http://www.perfprotech.com/store/ass....aspx#assembly
If you don't feel like shopping around locally you can get the seal and o-ring here.
http://www.kcmarinetr.com/Default.aspx
picklenjim is offline
Old 02-05-2012 | 12:05 PM
Wow that sounds great if that is your number on the link you sent i will call you tomorrow.Probley make it 2 sets the other motor will be out soon and i will do that also.
Thank You.
Old 02-05-2012 | 01:32 PM
Thank You.
Not my number. That's a guy, Kirk Casey in Bellingham Wa. that has a boat repair shop. He collects, rebuilds and sells these old Merc Trans transmissions. Parts are pretty much unavailiable from mercury as these were last made around 1980.
Old 02-05-2012 | 02:26 PM
KC MARINE is da man on that TRANS
GoFastSonic is offline
Old 03-18-2012 | 10:59 AM
ok i have called kc marine 2 times and i may be giving him the wrong info on what i need or the seal i order is wrong from the marine parts shop.Any other help on a exact part number and by make .for a merc trans
Old 03-18-2012 | 12:35 PM
your other option is scaring up a pair of Borgs...
dereknkathy is offline
Old 03-18-2012 | 12:38 PM
Merc is calling it the pump cover seal, however I would tell KC you need the " Input shaft seal". They'll know what you mean.
Another way is remove the seal and measure the outside diameter and mic the shaft and take the seal and measurements to a place that specializes in selling bearings and seals.
