fixx
the exhaust bellow is only their to keep from ruining the ujoint bellow with the heat whyle on plane..not needed if your going to block it off and yes their are 2 types of gimbal bearing pullers,,slide 3 jaw slide hammer and a threaded rod style with plates to pull the bearing..still need the instalition tool tho.
Do you heat the pin or the gimbal ring itself? Curious about burning the paint.
i stick a jack handle into the gimbal bearing and rotate it part way. then hit it with a punch or long screwdriver to rotate it sideways. then it pulls right out, leaving the cage behind. then clean out inside of cage and pump some grease in to make sure it isn't plugged. put new bearing onto same jack handle and smack cage to rotate it off bearing. then you put new bearing in sideways and rotate it straight. no puller needed. there are 2 slots in bearing cage to remove reinstall bearing. MAKE SURE that you see them before you do this. if prev bearing was installed backwards, the slots face engine and this is not possible. also, when rein stalling bearing, make sure the grease hole in bearing is forward and lined up with grease slot in cage. otherwise it can't be lubed and will have a short life. i don't like pressing cages into and out of the housing. it gets a little bigger with each time done.
Originally Posted by jason y
(Post 3623605)
what i was thinkin as well... got my pins out earlier today 5/8s allen on three of course the 4th was stripped out couldnt beat the next size up in it had to beat a snapon extractor in it then heat with propane torch finally gave way... i know snapon tools are high but these screw extractor set about 30 peice has saved my ass enough to justify buying it.. all on stuff i had nothing to do with until it needed repair.. of course ill be installin new pins..
[IMG]http://i705.photobucket.com/albums/w...r/DSC_0379.jpg[/IMG] [IMG]http://i705.photobucket.com/albums/w...r/DSC_0383.jpg[/IMG] [IMG]http://i705.photobucket.com/albums/w...r/DSC_0378.jpg[/IMG] Here are some pics of a home made rig I used to pull the gimbal bearings. [IMG]http://i705.photobucket.com/albums/w...imbalPull3.jpg[/IMG] [IMG] http://i705.photobucket.com/albums/w...imbalPull2.jpg[/IMG] [IMG]http://i705.photobucket.com/albums/w...imbalPull1.jpg[/IMG] [IMG]http://i705.photobucket.com/albums/w...imbalPull5.jpg[/IMG] Take your time...think it through...save big bucks:evilb: |
Originally Posted by cheech
(Post 3625678)
(Post 3625678)
(Post 3625678)
yea i heard the bearing in mine to i knew it was bad where the bellows goes on are good but i had one bolt break off in the housing and stud corroded in half.. so both my transom plates might/are junk
(Post 3626522)
Originally Posted by bustedbrick
(Post 3622453)
Bought the hinge pin tool from BAM. Soaked pins from the inside of the gimbal ring with PB Blaster for a few days (one application a day) before trying it. Took a 1/2" breaker bar and a 2ft pipe "extension". They came loose with a loud bang.
_________________ download 5000 backlinks |
| All times are GMT -5. The time now is 06:08 PM. |
