-   -   need help with a bravo one rebuild (https://www.offshoreonly.com/forums/drives-lower-units/272225-need-help-bravo-one-rebuild.html)
mikeoutlaw24 03-10-2012 03:45 PM
i have a older bravo one upper and i am putting a newer gear set in .do i use the older thrust bearing assembly or do i use the newer black thrust bearing thanks mike
Mr Gadgets 03-11-2012 10:02 AM
Mike are you referring to the bearing inside the gear? The one next to the cone spring? The old one was a two piece and the new one is a one piece, black on one side. Use the new bearing with the new gears.
Dick
mikeoutlaw24 03-11-2012 04:56 PM
thanks for the help
thanks for the help mike
johnnyboatman 03-11-2012 09:19 PM
yes use the new style.
sac 03-12-2012 10:02 PM
The silver side goes next to the spring
