mercruiser drive - choices >
Old 03-26-2012 | 05:51 PM
Default mercruiser drive - choices
have a pair of mercruser inline 6cyl 292 cu. inch engines late 1960s. can a new alpha drive and transom assembly be mated to these engines? looking to possibly have engines rebuilt and installed in my magnum 25.
captrod28 is offline
Old 03-26-2012 | 05:58 PM
i am pretty sure the flywheel cover (what gets called the bellhousing in the automotive world) is the same as big and small block v8's. so it should work. biggest question is how long is the engine compartment? motor is a good 8-10 inches longer than a 350. and can you still get exhaust manifolds? and will you be able to in 5 years?
dereknkathy is offline
Old 03-26-2012 | 09:09 PM
One of the members here just pulled a pair or 292's out of a '79 255 Formula Liberator so I'm pretty sure you are ok. The In line six and the SBC V8 use the same bolt pattern for the Bell Housing. Your six's are probably 2: piece rear main seal and you need an early 2: piece rear main seal flywheel.
if you get ready to do it I have everything you need to convert to Mercruiser Pre Alpha No 1 Transom Assemblies. The No 1 T/A's will accept Alpha Gen I drives. Jason Y on this forum has the exhaust set up and other stuff you need for those 292's.
The answer is yes ..it can be done and I think it would make a cool restoration project.
sprink58 is offline
Old 04-04-2012 | 09:55 PM
wonder what happened with this guys plans? i do have everything out of my boat still ... mines a 77 sprink..
jason y is offline
Old 04-04-2012 | 10:03 PM
Jason...send him a PM...you never know ...you might hook something up.
sprink58 is offline
Old 04-05-2012 | 12:16 AM
sac
Some of the early in-lines had shorter splined shafts so check on that as well.
sac is offline
