Outdrive Knocking
Old 04-20-2012 | 02:08 PM
Default Outdrive Knocking
I have a 5.7 350 Magnum Engine on an Alpha GenII Mercruiser outdrive. There is a knocking in the outdrive when going over 20 mph. There is no noise at all when going under 20 mph. Knocking is not in the engine. I checked the u joints and they were tight. There is no metal shavings in lower unit oil. Any ideas what could be the problem?
Thanks!
williams6 is offline
Old 04-20-2012 | 03:02 PM
Something is loose and the torque at speed is causing the knocking...Are you sure its the outdrive? Could it be your flywheel? Bellhousing?
Powerquest_Baby!! is offline
