Bravo lower shift cable >
Old 05-07-2012 | 02:54 PM
johnnyboatman's Avatar
Default Bravo lower shift cable
WHEN INSTALLING a new cable how do you adjust it so when you put the drive back on you dont have to adjust it ten times to get both gears
johnnyboatman is offline
Old 05-07-2012 | 05:41 PM
Get both tools and follow the steps in the book, its straight forward and easy to do.
waconda is offline
Old 05-07-2012 | 06:01 PM
blue thunder's Avatar
Put the barrel on the cable in the same spot as the old cable. That will get you close if not right on if you don't have the tool.
blue thunder is offline
Old 05-08-2012 | 11:15 PM
Buy the tool and save yourself grief. It's only about $30.
ildukhunter is offline
Old 05-09-2012 | 05:54 AM
seafordguy's Avatar
I made a tool by cutting a slit in a paint stirrer with a saw. Took about 30 seconds and worked great
seafordguy is offline
Old 05-09-2012 | 08:54 PM
where can i get the tool?
Old 05-10-2012 | 06:46 AM
Parts #s are 91-12427 Shift cable adjustment tool and 91-17262 Core wire locating tool.
Bravo Shop has them in stock.
waconda is offline
