Play in the Shifters, hard to find nuetral, help???? >
Old 05-12-2012 | 10:02 AM
Default Play in the Shifters, hard to find nuetral, help????
I have 2 502's with Bravo One drives. Forward and reverse work fine, just sometimes it is hard to tell if the lever is in nuetral or notwhen you try to get in nuetral. Anyone have any knowledge what to look for? Thanks in advance.
TooManyToys is offline
Old 05-12-2012 | 11:58 PM
Mr Gadgets's Avatar
Charter Member #601
TooMany,
drain some lube out and pull the back cap on the drive. There is a detent ball and spring in the cap. They will come apart or get stuck, causing problems. If it is colapsed, it could cause the symtoms you are describing.
Hope that helps.
Dick
Mr Gadgets is offline
