XZ outdrive problems? >
Old 05-18-2012 | 01:45 PM
Default XZ outdrive problems?
I have a 2003 Formula Fastech 382 with Mercury Racing HP525's and Mercury Bravo XZ drives. The starboard drive failed after about 155 hours and the port drive failed about 10 hours later. Am I the most unlucky man on the water, or are there known issues with the XZ drives?
Skip is offline
Old 05-18-2012 | 02:59 PM
t500hps's Avatar
21 and 42 footers
Your "normal". The problem is the 11-12,000 lbs in front of those drives. If I remember correct, XZ's aren't much better than regular Bravos. I lost an XR on my 2002 382 and I tore the drives down every winter to inspect and changed the fluid every 25 hours.
t500hps is offline
