-   -   volvo to BW velvet drive (https://www.offshoreonly.com/forums/drives-lower-units/276912-volvo-bw-velvet-drive.html)
wirlybird 05-21-2012 04:02 PM
Hi Guys does any one know if the Volvo TAMD 63L/P will bolt to a velvet drive?
If so what parts are required?
Biggus 05-21-2012 04:19 PM
You need a flywheel housing adapter and dampener for Velvet Drive. I think the TAMD63 is SAE 3, but not positive.
http://www.surplusman.com/Detail.php?itemid=3454
I would not run the stock Velvet Drive, It would need to be upgraded to handle the torque of that engine.
wirlybird 05-21-2012 04:37 PM
oh i see would it have more torque than my offshore 454?
i thought i was going down in power seems like i was a bit off the mark.
the engine comes with a ZF 220A but i dont think that will hook up to the TRS
Biggus 05-21-2012 05:16 PM
I'd try to find a BAM 1350 (modified VD) that should work for you. The ZF is a great trans but as you know, it wont work for a TRS application.
wirlybird 05-21-2012 05:34 PM
Thanks Biggus great to get some experianced advice :)
