-   -   Broken upper gears from hitting something? (https://www.offshoreonly.com/forums/drives-lower-units/277677-broken-upper-gears-hitting-something.html)
My Addiction 05-31-2012 07:49 PM
I'm pretty sure I hit something while cruising. shortly there after there was a rough/violent vibration. I shut it down and got towed in. I noticed a small dent in the prop( bravo with a solid hub ). Is it possible that the gears could have broke and the prop only has a minor dent in one blade?
I Removed the drive and while rotating the drive shaft you can feel it skip a gear. This happens in forward and reverse.
Thanks.
mike tkach 05-31-2012 10:39 PM
i have trashed my share of bravo&xr drives,for me they never break when i am beating them,it always lets go when im crusing,and they do shake&vibrate like crazy just before they let go.i doubt you did the damage because you hit something,the drive is just a pizz poor design,that does not like torque.
JaayTeee 06-01-2012 05:32 PM
1 Attachment(s)
Here's a couple of XR driven gears from my scrap collection
Didnt hit anything.....they're just junk....both wiped out the case too.
