Best prop size ?
Old 07-22-2012 | 01:04 PM
Default Best prop size ?
30' scarab s type.
Converting to stock 7.4 mpi' s
am going to raise x dim 2"
what props should i be running?
JETTDOGG is offline
Old 07-22-2012 | 08:09 PM
REDCHECKMATE's Avatar
2,3,4,5or6 blade but no 1 blade
REDCHECKMATE is offline
Old 07-23-2012 | 11:22 AM
TWO BLADE - OAR AND OAR LOCKS ARE CHEAP..........SHOULD GET ME PAST THE CHECKMATES
JETTDOGG is offline
Old 07-25-2012 | 05:33 AM
taking out TRS's? putting in bravos? you are spending enough time-money-effort getting boat together as-is. get it together and try the props you already own. THEN, when you know what you have you can get a better idea what props you want to try next...bblades can maybe give you an idea, but he will say the same. you need rpm and speed numbers for comparison.
dereknkathy is offline
