Bravo 1 takes a while to engage
One of my bravo 1 drives takes a couple of extra seconds to engage in reverse. I switched my props around the other day so that that drive is going into forward for reverse and I have the same problem. It doesn't do it either way I have the props as long as Im putting it in forward. When I'm at the dock it will slams in when I rev it up to maneuver. Any suggestions? Thanks Eric
I've seen many Bravo's do this if not adjusted properly. Doesn't matter if you switch props from RH to LH, the outdrive doesn't know what prop is on the shaft.
