bravo trim cylinders leaking off >
Old 08-17-2012 | 01:46 AM
Originally Posted by c_deezy
if its not leaking externally then the issue is in the valve body of the trim pump. Had the same thing happening on my original trim pump, replaced it with another one and no more droop.
x2
Originally Posted by fleg1
I'm just worried that when I'm running that the drive will creep down at a faster pace, and that I'm gonna have to keep bumping the trim up to keep it at the correct trim angle..
Yes, that will happen
Griff is offline
Old 12-13-2012 | 05:30 PM
Go to a dealer and ask for the two shipping plugs that come in rams or shells. Trim the unit to the top and remove the two hoses with the unit proped up. Put plugs in the holes and unprop overnite. Repeat on the other side. Both rams should hold or theyu have an internal leak. If both test good the pump is faulty or a hose/connections leak.
good luck
Amarket Owner is offline
Old 12-14-2012 | 07:09 AM
Fleg1 if you have to buy new pump /Ebay about $200/ $ 230 new pump it was posted on here about 6 weeks ago .
paul buckner is offline
