Bravo derivative to handle 750HP >
Old 04-15-2013 | 08:08 PM
  #61
Panther's Avatar
Frank's Marine Service
Originally Posted by 1 MAIDEN AMERICA
That's the problem with the newer XR gears. No metal on the magnet because the faces hold up great. A tooth just decides to let go nowadays. My last one busted a tooth. Rotate the gear 180* and it looked perfect. It didn't get chewed up because it locked up and broke the stub shaft in the coupler.
Been there and done that in 2005 with Imco Extreme SC's. How they dealt with it sorta burned me on the IMCO brand. Glad I got rid of Bravo's.
Attached Thumbnails Bravo derivative to handle 750HP-blown-imco-2-006.jpg   Bravo derivative to handle 750HP-blown-imco-001.jpg   Bravo derivative to handle 750HP-blown-imco-008.jpg
Bravo derivative to handle 750HP-blown-imco-2-004.jpg   Bravo derivative to handle 750HP-blown-imco-2-007.jpg
Panther is offline
Old 04-16-2013 | 02:50 PM
  #62
What brand top cap is that? is the drive shower integrated into the cap?
richanton is offline
Old 04-16-2013 | 08:56 PM
  #63
X2
Same exact thing on an 8 hour old drive going 30 MPH. Just above plane in zero visibility on radar heading to long beach.
Never got a chance to beat on anything - tooth went - and the whole train stops... snapped shaft ...same deal.
Have about 100 hours of the rebuild mostly from easy lake running.
UD
Uncle Dave is offline
Old 04-17-2013 | 10:46 AM
  #64
Panther's Avatar
That is the top cap from an IMCO Extreme SC. They integrate the shower into the top cap.
When I blew this drive the plate which bolts to the top cap (it looks like a disk) also blew off. My buddy who was running next to me saw a shiny, sparkly thing fly through the air moments before the drive blew apart.
Panther is offline
Old 04-17-2013 | 12:27 PM
  #65
Someone needs to catch that with a go pro.
waconda is offline
Old 04-17-2013 | 01:35 PM
  #66
PatriYacht's Avatar
Can an IMCO SC lower be used with a BMAX upper?
PatriYacht is offline
Old 04-17-2013 | 02:11 PM
  #67
Panther's Avatar
Yes, but you'll need a BMax vertical shaft. Basically a BMax vertical shaft is a little shorter and has larger splines. There was a member here on OSO that had a setup just like that on his Fountain with 800's.
Panther is offline
Old 04-24-2013 | 09:26 AM
  #68
Originally Posted by johnnyboatman
on a twin application if driven correct the xrs will survive
on this forum, driven correct would be wide open as often as possible, right???
tjhuyser is offline
Old 04-24-2013 | 09:44 AM
  #69
Originally Posted by Rik
To bad you are limiting your options to a Bravo style drive
With all the XR's and IMCO extremes i went through i should have went the Arneson...but at that point i was commited to a Bravo config.
If i could turn back time it would have saved me thousands.
But my Max's and Modified IMCO lowers are surviving.
Back4More is offline
Old 04-24-2013 | 09:52 AM
  #70
Panther, I made XR/IMCO salads just like those... LOL
BTW, I need to see that video again to get me in the mood for the season. Link please
