knife edge skeg ?? >
knife edge skeg ??
knife edge skeg ??
Old 10-30-2012 | 08:06 PM
Default knife edge skeg ??
after installing my nosecone should I knife edge the skeg or leave it alone ?
dave269 is offline
Old 10-30-2012 | 08:40 PM
I look at it this way. If you knife edge it and hit a stick, can, or bottle it will nick easier.
Back4More is offline
Old 10-31-2012 | 12:26 AM
if you look at a lower that has been done by wilson performance,you will see how to properly knife edge a lower.they come to a sharp point.
mike tkach is offline
Old 10-31-2012 | 08:59 PM
so knife edging the skeg wouldn't be a bad idea ?
dave269 is offline
Old 11-01-2012 | 04:28 PM
Default fixx
mine is,,no more prop slip...dont just v it,,you have to go back a few inches and blend it forward..if you nic it thats what they make tig welders for..
FIXX is offline
Old 11-02-2012 | 02:08 AM
tomas_wallin's Avatar
What was the difference in slip before and after. Did you gain any speed or something else?
tomas_wallin is offline
Old 11-02-2012 | 07:13 PM
it was on a older volvo..was like 20% before ..also back cut the skeg to load the prop with more water..
FIXX is offline
Old 11-03-2012 | 04:31 AM
Originally Posted by riverrat
Send it to Wilson in Florida and they will gain you some real speed and they do more then just knife edge the skeg . you wont make the gains yourself with a file & a d.a. sander lol ,don't belief everything you read on the net. good luck
Jeff
That is not an option since I'm located in Sweden...
But anyway - who/what's Wilson?
Old 11-03-2012 | 06:01 AM
This is a lower done by Wilson. The skeg looks knife edged:
thirdchildhood is offline
Old 11-03-2012 | 06:42 AM
Is that a -3 IMCO? Do you know if the Wilson adjustments made any difference? I'm guessing the lower was for a 22 Donzi?
