-   -   -3's with ssm Props (https://www.offshoreonly.com/forums/drives-lower-units/287804-3s-ssm-props.html)
mcprodesign 11-24-2012 10:43 PM
Originally Posted by bor (Post 3819917)
I ll hope to get the prop next week and if the weather allows it gonna try it asap but the forecast says it gonna freeze next week ,but long as there s no ice in the water we go and the cold give a few extra hp !
I hope it gets there . It would be great to test before the ice !!
bor 11-29-2012 10:50 AM
I got it !!
http://i1007.photobucket.com/albums/...1/IMG_1529.jpg
Now hope that the weather will be good enough sunday .
mcprodesign 11-29-2012 07:42 PM
Originally Posted by bor (Post 3823499)
I got it !!
That's bad ass!!
bor 12-02-2012 10:47 AM
chopper test
Went out today ,it was pretty cold 39 F and lots of rain this morning but cleared for a few hours this afternoon so got the boat and go testing as it could be the last time this year !
It came quite normal on plane slightly longer as whit the bravo so that s not bad as it have a blade less and felt good
got it up to 91 mph @ 6000 rpm but at that point when trimming a bit more up the prop blows out .
it gives quite a bit more bow lift as the boat is more out the water now so that s good and what I wanted but the 28 stock bravo 1 is still the fastest but that was whitout the 1" spacer .
the next step I want to do is get the spacer out and look what that does ,as that was the fastest set up whit the 28 bravo .
here s the vid of this afternoon not to good whit the phone :whistle:
http://www.youtube.com/watch?v=e-7zXThLDmY
http://www.youtube.com/watch?v=5siFOX5p1I8
mcprodesign 12-02-2012 10:31 PM
The boat looks really hooked up nice!! Is the bow where you want it in the video? looked good from here. Too much trim just puts the front of the nose cone down thus creating more drag right? Thank you for sharing !!
professor_speed 12-02-2012 10:51 PM
Boat is looking good have you thought about running a pro et? that would be 4 blade like the bravo 1 but be the profile of the chopper. I would be looking to get that prop if it were me. also Hoss props will be making chopper props for the blackhawk in the spring.
JRider 12-03-2012 08:21 AM
Interesting, I picked up an offshore outboard over-hub style 4 blade cleaver to run on an XR. I have often wondered why more people do not run small hub style props on bravo style drives.
bor 12-03-2012 12:28 PM
I think the don t do it because there usually are smaller in diameter and you lose quite some blade area behind the bullet which is bigger as the outboard ones .
However it run good no strange things and give the lift I wanted but the bravo was quicker so I think I go for a customized bravo from bblades .
Professor, I have looked at it but I m a little afraid it will give to much stern lift ,will discuss it whit bblades .
I wish someone have one to try but there are not many props available in europe !
yep I live in the wrong country !
