Bravo X vs XR
Old 11-24-2012 | 02:38 PM
glen george's Avatar
XRs will be on my winter wish list. Victroy marine has them new or reman. Best prices so far. Thinking now XR uppers new. -2 imco lowers.
glen george is offline
Old 11-24-2012 | 09:40 PM
Originally Posted by stirling
What part let go on the bravo X drive ? lower /upper ?
A.J
Upper
Donskihp is offline
Old 11-24-2012 | 09:47 PM
I replaced my upper with Teagues Platinum drive. Its A beefed up XR. Grears are crygogenly ? frozen which makes them a lot tuffer, and has the teague vertical flex shaft. I also had teague rebuild my lower to a XR
Donskihp is offline
Old 11-24-2012 | 10:04 PM
I would save my money for the Imco SCX. The newer Bravo XR gears are just not that strong. Your bravo prob has older gears that were forged stronger. Just keep running what you have untill they break. You also could find a used matching bravo and rotate that through as a spare drive. They are the least expensive and prob will last just as long as a bravo x or xr. When a drive breaks put the spare on and have the broken drive fixed.
No matter what, EVERY bravo based drive WILL wear out the gears way to fast. Bravo, Bravo X, Bravo XZ, Bravo XR, Bravo III, Imco SC, Max machine worx, All american Drive, B-Max lower.
offshorexcursion is offline
Old 12-15-2012 | 09:18 AM
Default Bravo xr
I have bought these XR drives, 3 hour use after IMCO rebuild on a 35 donzi with 525s, now i have to fine the right engines to replace my 502mpi with.
Old 12-15-2012 | 09:46 AM
johnnyboatman's Avatar
If you need engines i may have some fresh 540s forsale.
johnnyboatman is offline
Old 12-15-2012 | 09:49 AM
installed an XR when i went with the blower setup...too early to rate the drive,as engine is just broken in (5-6 hours)
pqjack is offline
Old 12-15-2012 | 09:50 AM
Thinking about the 509s in the swap. I see your tall deck 540s @ 24K.
Old 12-15-2012 | 10:24 AM
Would the tall decks fit? How close would that put the headers!
Wildman_grafix is offline
Old 12-15-2012 | 10:40 AM
drives are 34"
